vcPtpTarget
An object with properties to define necessary information to plan and execute a point-to-point motion. A kinematics behavior is required to execute a motion with this target type.
Module: vcRobotics2
Parent: vcMotionControllerTarget
| BaseName | String | RW | Gets or sets the name of the base frame to use. This frame must exist in the controller for the motion to succeed. |
| BlendingType | vcMotionBlendingType | RW | Gets or sets the desired blending type. Also see BlendingValue. |
| BlendingValue | Real | RW | Gets or sets the value that defines how early blending towards the next motion may start. Also see BlendingType. |
| DriverReferenceValues | list[Real] | RW | Gets or sets optional internal driver "guess/desired" values that will be respected by the system when solving the final values at the target.See moreThis is useful when the desired turn values or configuration is known. If left to none or an empty list, the system will use the actual initial driver values, thus minimizing the change of configuration/turns to reach the target. NOTE: For retrieving reference/target values for a specific configuration, use vcKinSolver.inverse -method. |
| ExternalDriverValues | list[tuple[Integer, Real]] | RW | Gets or sets the list of external driver values to reach at the end of the motion. The integer is the external driver's index in this controller. |
| IsExternalTcp | Boolean | RW | Gets or sets a boolean value that affects how Target is interpreted.See moreWhen set to true, the Base frame is used as the external/static tool and the Target is given in the Tool frame coordinates (tool-to-base). When set to false, the Target is given in the Base frame coordinates (base-to-tool). |
| Target | vcMatrix | RW | Gets or sets the target matrix which defines the final internal driver values at the target, along with base, tool, and external driver information.See moreThe target is given in base coordinates, also see IsExternalTcp. The given internal driver reference values are used by the system to find the nearest possible values to reach the target. The final internal driver values are resolved when the target is added to the controller for execution. |
| ToolName | String | RW | Gets or sets the name of the tool frame to use. This frame must exist in the controller for the motion to succeed. |
| VelocityPercent | Real | RW | Gets or sets the desired velocity percentage as decimal value [0, 1.0]. |
